JoWa Postad Juni 4, 2022 Författare Dela Postad Juni 4, 2022 VLC 3.0.17.4 Changes between 3.0.17.3 and 3.0.17.4: Service Discovery: Fix UPnP regression on Windows Filer: https://download.videolan.org/pub/videolan/vlc/3.0.17.4/ Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad December 1, 2022 Författare Dela Postad December 1, 2022 VLC 3.0.18 VLC 3.0.18 is the nineteenth update of “Vetinari”: Major adaptive streaming updates Codec updates Fix seeking for some formats (e.g. oog) Fix playback of numerous files on some older GPU graphics cards Avoid a playlist live loop in case of only very tiny or failed items Many updates of third party libraries Numerous crash fixes Fix some SMB protocol behaviours Fixed multiple security issues, which are detailed here Ändringslogg: https://code.videolan.org/videolan/vlc/-/raw/3.0.x/NEWS Filer: https://download.videolan.org/pub/videolan/vlc/3.0.18/ Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Oktober 9, 2023 Författare Dela Postad Oktober 9, 2023 VLC 3.0.19 Ändringslogg: https://code.videolan.org/videolan/vlc/-/raw/3.0.x/NEWS Filer: https://download.videolan.org/pub/videolan/vlc/3.0.19/ Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad November 2, 2023 Författare Dela Postad November 2, 2023 (redigerade) VLC 3.0.20 VLC 3.0.20 is the twenty-first update of “Vetinari”: Improves playback of numerous formats including rendering of certain subtitles Codec updates Fix FLAC rendering quality issue Fix playback of numerous files with some older AMD GPU graphics cards drivers Add AV1 hardware decoding on Windows Many updates of third party libraries Improve SMB compatibility with Windows 11 hosts Update of most translations and add new ones to Esperanto, Interlingue, Lao, Macedonian, Burmese, Odia, Samoan and Swahili Fixed multiple security issues, which are detailed here and there Ändringslogg: https://code.videolan.org/videolan/vlc/-/raw/3.0.x/NEWS Filer: https://download.videolan.org/pub/videolan/vlc/3.0.20/ Redigerad November 15, 2023 av JoWa Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
JoWa Postad Juli 3 Författare Dela Postad Juli 3 VLC 3.0.21 VLC 3.0.21 is the twenty-second update of “Vetinari”: Improves playback of numerous formats including rendering of certain subtitles Codec updates, notably dav1d, ffmpeg, libvpx NVIDIA TrueHDR to generate a HDR representation from SDR sources Super Resolution and VQ Enhancement filtering with AMD GPUs Add support for HTTP content range handling according to RFC 9110 Many updates of third party libraries Fix regression on macOS causing crashes when using audio devices with more than 9 channels Update of most translations of the user interface Fixed one security issue, which is detailed here Ändringslogg: https://code.videolan.org/videolan/vlc/-/raw/3.0.x/NEWS Filer: https://download.videolan.org/pub/videolan/vlc/3.0.21/ 1 Citera Länk till kommentar Dela på andra webbplatser Fler delningsalternativ...
