Thunderbird 128.3.2
JoWa
  • 2 veckor senare...
Fix Font Scaling and Density Issue on Thunderbird 115 Upgrade
If you have recently upgraded to Thunderbird 115 “Supernova” and noticed a smaller font size or a presentation that feels too compact, there might be an easy solution. You should be able to simply change the font from the app menu to achieve your ideal font setting by clicking the ± to change the font size globally (see below).
  • 3 veckor senare...
  • 1 månad senare...
  • 4 veckor senare...
